Discussion topic: New sky max hub (router) needed how do I order one?
Message posted on 25 Jul 2025 09:05 AM
Hello ,
my Router (max hub) has totally broken , how do you get a new one ? It's owned by sky , yet there is no clear route to get a new one . Why have they made it so hard to communicate with them?
Message posted on 25 Jul 2025 09:33 AM
Re: New sky max hub (router) needed how do I order one?
Message posted on 13 Sep 2025 07:47 AM
I have tried the link myself, my router is clearly broken (water damaged) the link is as hekofull as a chocolate teapot. Calling the number doesnt help either , no one answers.
Thinking it will be quicker to cancel and order with a new provider. I.ve been with Sky for 35 years and their support is now useless
Message posted on 13 Sep 2025 07:51 AM
@Warwick4 @MrBarry
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline. The forum doesn’t allow the display of other numbers.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: for any customer whose services are restricted due to a missed payment phone contact is unlikely to work.
🟩 online help via this link
https://www.sky.com/help
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note ~ ROI customers 🔹If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
Message posted on 13 Sep 2025 07:51 AM - last edited: 13 Sep 2025 08:06 AM
@MrBarry Not open until 8am!
