Discussion topic: Internet not working
Message posted on 03 Aug 2025 08:09 PM
Message posted on 03 Aug 2025 08:16 PM
Re: Internet not working
@JodieDoyle
If your Sky broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
