Discussion topic: Internet not working
Message posted on 24 Mar 2025 02:31 PM
The box is on and the power and wireless light are green but the internet light blinks amber and then goes off. The internet was working 30 minutes ago and I have tried to reset it several times but the light does not appear to be changing to green and the internet will not turn on.
Message posted on 24 Mar 2025 02:43 PM
Re: Internet not working
@Ruby41
