Discussion topic: Connection details
This message was authored by: Db19801980
Connection details
Currently on sky hub max but wanting to change to my own modem to replace this.
what are they connection username and password to give my new modem connection?
thanks
Re: Connection details
@Db19801980
Are you in the uk or ireland?
Are you on full fibre fttp or part fibre fttc vdsl
Avatar for Db19801980
Uk
and it's only vdsl
Hi @Db19801980
You'd need a router compatible with DHCP Option 61 and use the connection string abc12345@skydsl|abc12345
I would also note that some areas & routers can authenticate automatically using IPv6 PD if you enable IPv6 on the routers WAN side.
I am NOT a Sky Employee
