Discussion topic: Internet not working
Message posted on 28 Feb 2025 11:53 AM
I have 2 green lights and one orange light on my router. Orange is Internet
Message posted on 28 Feb 2025 12:10 PM
Re: Internet not working
@Clarissa6
If you’re still having problems you may need to call Sky to report it (dial 150 free from your Sky Talk landline).
In addition~
▪️This link providers information about the coloured lights on the various hubs
▪️ For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
Message posted on 28 Feb 2025 12:14 PM
Thank you all sorted its now working properly
