Discussion topic: Can’t connect to WiFi in certain rooms
This message was authored by: lewisevans24
I can't connect to my wifi in the living room, every other rooms of the house if fine.
Re: Can’t connect to WiFi in certain rooms
@lewisevans24
Is this because its out of range or are you getting any sort of error?
I am NOT a Sky Employee
Avatar for lewisevans24
I can put the pod right next to the router but still not connecting.
They sent a pod and it won't connect to the router anywhere, therefore the living room is still out of range. The pod won't automatically connect and when I try to do it manually it throws up an error.
@lewisevans24 the pod needs to be added to the account and appear in the My Sky app. If it isnt you need to talk to Sky to get that done.
I don't have a contact number for sky just automated messaging services
