Discussion topic: Internet not working WHY?
Message posted on 07 Oct 2025 12:42 AM
My internet isn't working. I'm late paying my tv bill but I have paid my broadband so why is it not working?????
Message posted on 07 Oct 2025 06:03 AM
Re: Internet not working WHY?
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
Message posted on 07 Oct 2025 06:24 AM
Same thing happened with my connection around 3 AM.. Hub itself is not connecting
Message posted on 07 Oct 2025 06:59 AM
@Gaurav2 if it is overnight msintenace causing your issue the connection should be back by now.
Message posted on 07 Oct 2025 08:21 AM
Hi, But its not.. when i check on downdetector there are 100s of reports of a wider problem.. I am not sure if its being dealt with urgency.. multiple restarts even this morning haven't helped..Kindly look into this with urgency please
Message posted on 07 Oct 2025 09:03 AM
Wider problems are always tackled 'urgently': why wouldn't they be?
Unfortunately an urgent response is not the same as an instant resolution.
Message posted on 07 Oct 2025 10:04 AM
@Gaurav2
l’m afraid you aren’t speaking to Sky Customer Services by posting here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
