Discussion topic: Internet not connecting
This message was authored by: Erinjohnstone12
My Internet has been going on and off for the past few days it's been off 90% of the time.., I've followed all the steps nothing works., I've tested my connection and it says everything is fine.
This message was authored by: mae-3
Re: Internet not connecting
@Erinjohnstone12
The community needs a bit more information, and at least the router stats to give us something to go by, there is a post at the top of the forum which explains how to post those router stats which should be followed right to the end carefully to do the process correctly.
Avatar for Erinjohnstone12
Port
Wan status down all stats 0
LAN status down all stats 0
Whlan 2.4GHz  up 903  0 0 618 0  uptime 00:7:23
whlan 5GHz up 3558 3795 0 43055 00:7:23
@Erinjohnstone12
Unless it is an area issue your Sky App logged into your account and run from the mobile 4G/5G network should be able to test the broadband line and allow you to book an engineer.
