Discussion topic: Internet light off for hub
Message posted on 18 Mar 2024 09:31 AM
My hub has green power and wifi lights, orange voice light and the Internet light is off. I tried testing my broadband online and it says my wifi has an issue but then when I run the wifi test it says it's fine. I can't get to any websites though.
Message posted on 18 Mar 2024 07:00 PM
Re: Internet light off for hub
Can you let us know what sort of router & connection you have, we'll get you a step by step guide on what to check.
The most likely thing is that a connection between your router and where your connection comes in has dissconected. try checking network plugs from your router are all pushed in fully(but don't force them)
let us know what happens
