Discussion topic: Internet light not on hub
Message posted on 05 Feb 2026 11:35 AM
There is no internet light on hub but wifi has gone down. Sky app says no issues in the area and everything looks good
Message posted on 05 Feb 2026 11:40 AM
Re: Internet light not on hub
@Katie330
