Discussion topic: Internet keeps going off
This message was authored by: Lukecart
Re: Internet keeps going off
@Lukecart
When it goes down the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
