Discussion topic: Internet keeps going down
This message was authored by: Robert55555
Got new sky internet last week but keeps losing wifi on work computer and tv. Not sure if its because its got internal brick walls but never had issue with kcom and got told this router is better ?
Re: Internet keeps going down
@Robert55555
From what you have said it could be an issue with the signal in your poroperty so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
