Discussion topic: Internet keeps dropping out
This message was authored by: Speedypeas
Message posted on 26 Oct 2024 11:46 AM
Hi all my Internet to my router keeps cutting out and I'm having to regularly every few days reset my router to reconnect. Anyone out there have any ideas to solve this problem
This message was authored by: mae-3
Message posted on 26 Oct 2024 12:32 PM
Re: Internet keeps dropping out
Frequent disconnections requiring a router reset can be quite frustrating. Here are some troubleshooting steps that might help:
- Check Router Placement: Ensure your router is in a central, open location, free from obstructions and interference from electronic devices.
- Inspect Cables and Connections: Verify that all cables are securely connected and undamaged. Loose or damaged cables can cause intermittent connections.
- Overheating: Make sure your router is well-ventilated and not overheating, as this can cause it to drop connections.
- Power Supply Check: Ensure the power adapter is functioning properly and delivering consistent power to the router.
- ISP Assistance: Contact your internet service provider Sky to check if there is a line problem or to request a line test.
If the issue continues, there might be a fault with the router itself, in which case you might consider contacting the manufacturer for support or a replacement.
