Discussion topic: Internet keeps dropping/loosing connection
This message was authored by: Shunasassie
Hi, I have broadband that connects to a Microfilter & it keep losing connection, it's been getting worse since oct 2024, twice a day if I am lucky & up to 11 time in 1 day if I am not lucky, when I want to do gaming stuff with friends online I have to use my mobile hot-spot(not sky mobile) what is more stable as I don't want to spend 10 to 20 mins reconnecting devices to carry on, more so if I am hosting the game as if I get kicked everyone gets kicked. I've changed the Microfilter & both cables no luck. Any ideas?
Re: Internet keeps dropping/loosing connection
@Shunasassie
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
@Shunasassie You could say what hub that you have from sky, and since you have swapped out the gear, but you may have a noisy line, do you have a telephone connected to the Filter and are you definatly on a master socket and not plugged into a telephone extension?
Avatar for Shunasassie
When I do line tests it all comes up fine, it's like to broadband hub or Microfilter forgets they are collected.
Standard black hub, had it 4yrs now never plugged/used in a landline phone & no extensions for hub, hub shelf is above the master shocked Only 2 things use the WiFi everything else it ethier cables (3 items).
@Shunasassie Link below to the sky hub's there is unfortunate no standard black hub as a helpful desription, take a look either the Q bus supect it will be the Broadband hub. Link further below about the stat's and needed to see how the line looks.
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
How to read your Sky Hub statistics
