Discussion topic: Wifi range
This message was authored by: Jordan87
Wifi range
The range on my wifi is extremely poor. It is located in the cupboard under the stairs, I have ensured it is clearly on the top and unobstructed, it doesn't reach 1 floor above or to the back of the kitchen which is the next room, around 8-10 feet away, I expect the package I have should provide more range than it currently is. I have followed the help suggestions on the sky website but nothing has helped with this problem.
Re: Wifi range
@Jordan87 Is there a reason for it to be in the cupboard, possible new build, all the Ethernet points meet in that location, etc.
If none off the above are what is required then look to get it moved out, worst place and you may wish to say also what hub you have and the service you got from sky!
