Discussion topic: Internet issues
Message posted on 03 Sep 2025 07:23 AM
Internet issues
The internet keeps closing on us. The orange light go on routers. Not sure why but we have no access to internet. Thinking about switching providers if this continues.
Message posted on 03 Sep 2025 07:36 AM
Re: Internet issues
@Mo_jo
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
