Discussion topic: No Internet connection
Message posted on 03 Sep 2025 07:06 AM
Message posted on 03 Sep 2025 07:09 AM
Re: No Internet connection
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
