Discussion topic: Internet dropping out every 10 min with amber light on voice too
This message was authored by Tinthebank1 This message was authored by: Tinthebank1
Internet keeps dropping with amber light on internet then on voice too before turning back on a minute later with the internet briefly going off completely sometimes or just staying amber until the voice+ internet lights go green again. Then it repeats every 10-15 min
Re: Internet dropping out every 10 min with amber light on voice too
@Tinthebank1What does the broadband test say when you run it?
Tinthebank1
Only voice disconnected here but both amber when it cuts out with internet light completely off on occasion. The phone has cut off a couple of times when this happens too
Tinthebank1
This message was authored by Daniel0210 This message was authored by: Daniel0210
@Tinthebank1
Your image contains your hub SSID so was rejected.
▪️ I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
Tinthebank1
Broadband and wifi say connected 
@Tinthebank1So have you ran the broadband test to see if it finds a fault?
Tinthebank1
Finds no fault when it's all green no fault in error then just cuts out minutes later at which point it can't run the test as no internet and the 192.168 test shows everything ok except voice like the picture above.
Tried reset button tried switching off at mains for a couple of minutes
Just started doing this yesterday suddenly after 18 months 😞
@Tinthebank1You don't need internet to run the broadband test, it can be done via mobile data.
Tinthebank1
The tests are fine.
Yesterday it worked perfectly then this morning I noticed the sky tv box was working but saying it wasn't connected to the broadband box (only the voice button on controller not working)
I connected it in the settings and now it keeps dropping again 🙃 so it's something to do with the TV box causing the internet to drop
