Discussion topic: Internet down during work call
Message posted on 17 Dec 2025 04:31 PM
Internet has dropped out during an important work call!
Message posted on 17 Dec 2025 04:33 PM
Re: Internet down during work call
@Gerald17
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Message posted on 17 Dec 2025 04:46 PM - last edited: 17 Dec 2025 04:47 PM
No domestic provider guarantees connectivity, and given the topology of the cabled national network that's impossible anyway. A more robust solution is to pay an additional monthly cost for automatic failover to a cellular network.
