Discussion topic: Broadband/wifi
This message was authored by: Ajs4
Broadband/wifi
Hi we seem to be having issues with wifi, things are buffing on the tv can you investigate please as I've run broadband and WiFi tests as per your sky and it says everything is okay but it's not
Re: Broadband/wifi
@Ajs4
We won't be investigating. This is a customer ▶️ customer discussion forum where we try to help other customers.
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
