Discussion topic: Internet doesn't work, needs to be fixed
This message was authored by: Wioletta89
Hello, My Internet doesn't work from around 2pm yesterday, I am wondering why if I paying my Skys" bills? I can't watch what I want and call to my family abroad because there is an issue. Pls fix it as I really need my network
Re: Internet doesn't work, needs to be fixed
@Wioletta89
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services.
