Discussion topic: Internet going down every 10 min
This message was authored by: OtakuMarvinPPG
My internet has been both acting slow and also been dropping every 10 or so minutes but MySky keeps saying everythings alright but it's not
Re: Internet going down every 10 min
@OtakuMarvinPPG
