Discussion topic: Internet does not seem to be working
Message posted on 12 Mar 2025 05:11 PM
I have ran tests and your saying my broadband is fine yet I'm having to use internet data to contact you and can't get items to connect including sky protect equipment
Message posted on 12 Mar 2025 05:37 PM
Re: Internet does not seem to be working
@popularfront
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services.
Message posted on 13 Mar 2025 07:55 AM
Thanks that's sorted. Also I wasn't aware of the community for advice
