Discussion topic: Internet connection
This message was authored by: yodasims
Internet connection
My router shows Internet connected but can't locate WiFi
Re: Internet connection
@yodasims if this affects all devices try restarting tge Sky hub if still stuck reset the unit which should take it baxk to its default settings. To rset a black hub press and hold in the reser pin until the power light flashes on the newer white hub press and hold in the wps buton until the led flashes which can take up to 30 seconds.
