7
This discussion topic has been answered Discussion topic: Internet connection is down
This message was authored by: femgee1968
Hi there
It appears that my internet nework is down at the moment. My broadband hub is not connecting
This message was authored by: cookiemonsteruk Answer
Re: Internet connection is down
@femgee1968
Could you use the service checker on your my sky app using 4g/5g mobile data. Hopefully if it detects an external fault it will let you book an engineer visit
@femgee1968
What colour is the internet light on the sky router?
Avatar for femgee1968
Re: Internet connection is idown
I can only see  2 green (power and wifi) lights, there is no Internet light  and 1 amber for voice
@femgee1968
I have already done that, and book engineer visit , although I have not received any notification of when the engineer would be able to come for visit .
@femgee1968
Is anything showing in my orders in your my sky app
This message was authored by: Vicky70
Same here! Been dropping in & out consistently all week, done all the troubleshootiing & resets possible.
Good luck, ive lost the will to live!!!
This message was authored by: Henryg67
Checked through my sky and it says everything is fine
