Discussion topic: Internet connection Inverness
This message was authored by Kirst5 This message was authored by: Kirst5
Since Sunday I have had issues with WiFi signal dropping out for longer and longer periods I'm unable to work from home and when I complete a Sky system check it advises no issues... Any help would be appreciated and yes I have done all the turning off and on resets etc., thank you
Re: Internet connection Inverness
@Kirst5Have you had the problem since the last time you did a reset of the router?
Kirst5
I have had it before and after
@Kirst5 Could you please post your router stats following the link below.
