7
This discussion topic has been answered Discussion topic: Internet and voice light off and amber
This message was authored by: Kelandra
The Internet light and voice light off. There is a guy outside fixing something yet it's saying no problem in the area?
This message was authored by: JimM1 Answer
Re: Internet and voice light off and amber
@Kelandra And in that case your lights are indicating that you have NO broadband connection, hopefully the fix that he is doing is not by mistake disconnecting you, mistakes do happen!
This message was authored by: Sarah-473
I have the same right now, the internet light has gone off
Avatar for Kelandra
Just weird how when you test the broadband at home it's showing no problems so obviously that's not showing accurate readings. There is 2 open reach vans outside just up the road so gonna ask them now xx
Avatar for Kelandra
Must be an issue then I'm in Warrington
Avatar for Kelandra
The open reach guy had made a mistake on something all fixed now good job asked them xx
@Kelandra That's when !"£$ happens, good spot well addressed, and stops you pulling all your hair out and kicking everything in sight.
Had you not done as you did then up the creek without the paddle!!!
Avatar for Kelandra
Exactly would have took days for them to come back otherwise xx
