Discussion topic: Internet Keeps dropping out
Message posted on 16 Dec 2025 10:00 PM
Hi,
My Internet keeps dropping out and lights n hub go orange, every time I go on my phone Internet and test the hub it says its working fine and no issues when clearly there is.
I have my PC hard wired into the router and that loses connection too.
Tia
Scott
Message posted on 17 Dec 2025 04:45 AM
Re: Internet Keeps dropping out
@Smwb
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
