Discussion topic: My broadband is not working
This message was authored by: Jojo+chatterbox
Our internet has gone off and says that service is ok we have done the trouble shooting but it is saying there is no internet connection pls help
Jo
Re: My broadband is not working
@Jojo+chatterbox
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
