Discussion topic: Sky max keep turning off
This message was authored by: Phaulline
My sky max kept of restarting
Re: Sky max keep turning off
@Phaulline
Any broadband issues between midnight and 7am could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
Avatar for Phaulline
But mine keeps on happening in the afternoon
@Phaulline
I offered that possible reason due to the time you'd posted so if that is not the case the first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
