Discussion topic: Intermittent issue with connection
Message posted on 16 Apr 2026 03:09 PM
Good afternoon.
I am having lots of trouble with our Internet ever since the apparent upgrade. It's horrible, our TV doesn't work properly and half the flat( tiny 2 bed flat) isn't covered by the WiFi signal. Kitchen and living room are mostly affected. The only place we get good signal is the bedroom where we don't really need it. When the engineer came out, he advised the router has to be in the bedroom due to the nature of wiring (needs to be a straight line) but we had nothing but issues since then.
thank you
Message posted on 16 Apr 2026 04:23 PM
Re: Intermittent issue with connection
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 16 May 2026 06:56 PM
I think the box on wall is playing up
Message posted on 17 May 2026 08:15 AM
@Stuart2087 wrote:I think the box on wall is playing up
If you're talking about a fibre ONT then what do you base that on exactly? What lights are showing?
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
