Discussion topic: I cannot connect to my wifi
Message posted on 17 May 2026 07:31 AM
My WiFi isn't connecting.
I have switched off...on a couple of times
I have gone to settings and following advice have held the button WPS in for several long periods
Still no connection
Message posted on 17 May 2026 08:06 AM
Re: I cannot connect to my wifi
@JANET1962 wrote:My WiFi isn't connecting.
Still no connection
What exactly is it you're attempting to connect? Does anything connect to WiFi? What lights do you see on the router?
If it's a Sky Q box and a Sky Max router (big white lump) then you have tto use the "other 3rd party router" option rather than the Sky router option and input the SSID & WiFi password from the card (unless you've changed it).
Not a Sky employee
Sky FTTP 500Mb to Max Hub
