Discussion topic: Intermittent connection on wifi
Message posted on 13 Nov 2025 01:47 PM
over the last 24hrs WiFi connection is being intermittent and test is showing it's working but it isn't
Message posted on 13 Nov 2025 02:20 PM
Re: Intermittent connection on wifi
@MarkPateman
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
