19 Dec 2024 02:07 PM
Hi, For the installation for Sky hub, I don't have a power adapter for the Hub, How can get it? May I get it from SKY.
19 Dec 2024 02:14 PM
@Agnes5 wrote:Hi, For the installation for Sky hub, I don't have a power adapter for the Hub, How can get it? May I get it from SKY.
If it's a new installation and your waiting for the Sky Hub the power adapter will be included.
if you have the hub but no power adapter for some reason then yes, you'd need to to call Sky to get a replacement .
19 Dec 2024 02:49 PM
Do you perhaps mean power for an ONT? That's the bit which tends to be missing if you've moved into a neww address.
