Discussion topic: Info needed
This message was authored by howler1 This message was authored by: howler1
Info needed
Hi all I have at present Sky Broadband Superfast and have just taken on sky max can you tell me if the new max will be better than my present fiber or is this sky max a new broadband that is faster
This message was authored by mormegil This message was authored by: mormegil
Re: Info needed
Sky max is a service with a new router/hub rather than a new product so your fibre will be the same unless you also upgraded from fttc to fttp?
Re: Info needed
@howler1
Max is a suite of extra-cost services including the loan of a new model of Hub meeting the WiFi 6 standard, with parental controls for device hours and supposedly some smart online security.  It cannot increase the speed you are receiving from the internet, but may improve local WiFi.
https://www.skygroup.sky/article/Sky-Broadband-releases-its-most-powerful-WiFi-yet
As @mormegil indicates, only moving from FTTC to G.fast or FTTP can get greater speed arriving at the address.
