Discussion topic: Inernet frequently dropping
This message was authored by: Chud1989
My Internet is dropping frequently every day. When I check the router the Internet light is orange or flashing orange. After a few minutes it returns to green and my service will be fine. The fault checker doesn't see a problem as service restores while completes its checks. I have turned tge router off and restarted but the problem remains.
Re: Inernet frequently dropping
@Chud1989 What sky Hub are you using, and also the connection type ie copper fttc to a master phone socket or FF Full Fibre to a ONT Modem?
Avatar for Chud1989
I believe it's the latest hub, model SR203. An upright black version with 4 LED but the voice light is not used. I am connected to a copper master socket. This set up hadn't changed since I moved in bar a change in router a while back. The connection was fine earlier in the week. Issues started on Thursday/Friday.
@Chud1989 Not the latest but good enough with your desc, if you can from the link below and allow all the data fields to fill in, post your stat's up once you capture the page, same as the table sample you see in the link. Will take a look to see what the line is like!
(1) How to read your Sky Hub statistics
Avatar for Chud1989
Details
help
Manufacturer
Sky
SR203
7.04.0205.R
A2pvfbH043p1.d26u
Model
Firmware Version
DSL Firmware Version
Modem
help
Modem Status
Traffic Type:
Line Rate-Upstream (Kbps):
Line Rate- Downstream (kbps):
Connected
PTM
20000
79999
2a02:c7c:5025:1900::1/128
IPy6 Loopback Address
Broadband Port
0 help
MAC Address
80:72:15:4e:50:2a
176.26.226.253
MER
255.255.252.0
176.26.224.1
90.207238.97, 90.207.238.99
fe80::22
Py4Address
Network Type
Py4 Subnet Mask
Gateway IPy4 Address
Py4 Domain Name Server
Gateway IPv6 Address
IPy6 Domain Name Server
IPv6 Global Address
2a02:c7c:5025:1900::1/64
fe80::8272:15ff:fe4e:502a
2a02:c7c:5025:1900::/56
Py6 Link Local Address
iPy6 Delegated Prefix
LAN Port
help
MAC Address
80:72:15:4e:50:29
192.168.0.1
On
255.255.255.0
Py4 Address
DHCPy4
Py4 Subnet Mask
IPv6 ULA
fd8b:3327:43d:0:8272:15ff:fe4e:5028/64
IPv6 Global Address
fe80::8272:15ff:fe4e:5029
On
DHCPy6
WiFi Port
help
Name (SSID)
SKYK8CDP
Europe
11 (2.4 G
Hz), 36 (5 GHz)
Enabled
Yes
Region
Current Channel
WiFi AP
Broadcast
Avatar for Chud1989
IPv6 Delegated Prefix
LAN Port
help
MAC Address
80:72:15:4e:50:29
192.168.0.1
On
255.255.255.0
Py4Address
DHCPv4
Py4 Subnet Mask
IPv6 ULA
IPy6 Global Address
DHCPv6
On
WiFi Port
help
Name (SSID)
SKYK8CDP
Europe
11 (2.4 GHz),36 (5 GHz)
Enabled
Yes
Region
Current Channel
WiFi AP
Broadcast
Avatar for Chud1989
I hope that's readable. Split over two messages with some overlap
@Chud1989 That is nothing like the sample table from the link, and you have just copied all the wrong info up on a public Forum!
If you have reached the Edit level go delete all that posted info!!!! Three dots edit level!!!!!
Avatar for Chud1989
Can I delete
Avatar for Chud1989
If I click the three dits I don't have delete as an option
@Chud1989 If you cannot edit let me know and i will report it and have a Mod take care off hiding the info!
YOU cannot delete EDIT is what you do! then wipe out all the data!
Avatar for Chud1989
I cant delete. Please would you proceed
@Chud1989 Ok reported Mod will take care off it when the get to it!
Avatar for Chud1989
I dont have edit either
Avatar for Chud1989
Regarding the problem. Youvreferred to a table but I cant see one. The link told me to go to the maintenance tab
