2
This discussion topic has been answered Discussion topic: Incorrect password
This message was authored by: KevfromFev
Incorrect password
Just had sky max hub delivered, it's up and running normally. However, I have just purchased an echo dot max (Alexa) and on set up the Wi-Fi name is recognised but whatever I try it keeps saying incorrect password and won't connect, the echo worked fine with my previous sky router, thank you in anticipation
Avatar for KevfromFev
This message was authored by: KevfromFev Answer
Re: Incorrect password
I thank you, I was in error, I misconstrued a capital I as. Lowercase L, it is now working fine and I thank you once again
@KevfromFev
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as shown on the hub itself so use upper case letting if required.
