Discussion topic: INTERNET DOWN - WHITE LIGHT ON ROUTER, HUB CHECKS ONLINE NORMAL
Message posted on 25 Aug 2024 07:29 AM
HELP - NO INTERNET SINCE LAST NIGHT
DONE THE CHECKS ON SKY - FINE, RESET ROUTER AND WHITE LIGHT BACK ON - NO INTERNET
Message posted on 25 Aug 2024 08:08 AM
Re: INTERNET DOWN - WHITE LIGHT ON ROUTER, HUB CHECKS ONLINE NORMAL
@EWFKEFMEKFERM powering down your hub forcat least an hour should clear the fault.
Posting in block capitals is considered shouting and as you are asking other customers for help is quite rude.
Message posted on 25 Aug 2024 08:47 AM
Ok. Thanks for that. Can you offer anything constructive or are you just giving me online etiquette advice?
Message posted on 25 Aug 2024 08:51 AM
@EWFKEFMEKFERM try reading my post I told you what do in quite short words so you should be able to understand it.
Message posted on 25 Aug 2024 08:51 AM - last edited: 25 Aug 2024 08:51 AM
If a Hub reset doesn't change the situation then the assumption would be there's a fault in the external circuit to the address which needs logging with Sky for investigation by Openreach (the latter of which realistically isn't going to happen until Tuesday at the earliest)
Message posted on 25 Aug 2024 08:52 AM
ok thank you. how annoying i only have sky stream.
Message posted on 25 Aug 2024 08:53 AM
yes that hasn't worked either i did that before posting.
Message posted on 25 Aug 2024 08:54 AM
thanks for the comments.
