Discussion topic: I having too much lag while playing games
This message was authored by: Sachinmaroli
Gaming is very laggy, even though the speed is good, the latency is very high and the game is lagging while playing online
Re: I having too much lag while playing games
@Sachinmaroli
If you have a black sky hub could you post your router stats
Avatar for Sachinmaroli
 thanks for your response, pasting the status
@Sachinmaroli
You are using wifi for gaming this will without be a major cause of latency
How far is the console/pc from the router.?
Is there anyway to use ethernet?
