Discussion topic: WiFi keeps dropping out
Message posted on 30 Aug 2024 02:10 PM
Message posted on 30 Aug 2024 02:14 PM
Re: WiFi keeps dropping out
Could you post your router statistics as shown below
Message posted on 30 Aug 2024 03:42 PM
Message posted on 30 Aug 2024 03:46 PM
If you click the maintenaoce tab along the top and sign in with
Username admin
Password sky or wifi password
At the bottom of maintenance click show statistics and post that
Message posted on 30 Aug 2024 04:42 PM
I'm having trouble I can't remember my password 😔
Message posted on 30 Aug 2024 04:45 PM
Did you change it?
The current wifi password is on the back of the router
If you did change it press and hold down the reset button on the back of the hub and then use the wifi password on the hub
Message posted on 30 Aug 2024 05:58 PM
Message posted on 30 Aug 2024 06:02 PM
That shows both wifi 2.4ghz and 5ghz dropping 3 minutes ago
How old is the hub. It may be worth contacting sky to replace it as both wifi bands dropping like that may imply a faulty router
Message posted on 30 Aug 2024 06:11 PM
Thanks for your help
