Discussion topic: Hub not got internet
This message was authored by: Jack186
Hi
broadband box has power option free, no light on internet, WiFi on green and voice on orange?
Re: Hub not got internet
@Jack186
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
▪️I AM NOT A SKY EMPLOYEE ▪️
