Discussion topic: No internet connection
This message was authored by: SamRawsthorn
I have no internet connection. I have unplugged and restarted the router and sky glass however it is still saying no internet connection.
Re: No internet connection
@SamRawsthorn
(For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support).
