Discussion topic: How to split my wifi sinal to 2.4 and 5ghz
This message was authored by: Brownie571
Message posted on 19 Sep 2024 06:11 AM
I need to split my wifi signal to 2.4 and 5g
Can anyone help
Find out more
Message posted on 19 Sep 2024 07:10 AM
Re: How to split my wifi sinal to 2.4 and 5ghz
@Brownie571 you can only split WiFi bands on the older bllack Sky hubs see https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
As you will see when you read that post you cannot split the bands on the newer white hubs so the workround is to temporarily disable the 5GHz band connect your problem devices and renable the 5GHz band.
