Discussion topic: How to connect my ring doorbell to my router
This message was authored by dem123 This message was authored by: dem123
I can't connect my ring doorbell 4 to my sky router.
Ring costumer services say I need to set my firewall to low but I don't know how.
Re: How to connect my ring doorbell to my router
@dem123
Seperate the wifi bands to give yourself 2 ssids
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
@cookiemonsteruk wrote:
@dem123
Worth trying, then synchronise them again one connected. Shouldn't need to do this though for the V4 as it's a dual band device. Mine has been used with the Sky Q Hub, BT Smart Hub2 and a TP-link router without issue.
"Sometimes, the only choices you have are bad ones, but you still have to choose"
