Discussion topic: How do I get wifi boosters?
This message was authored by: Damo1308
Just installed sky broadband router yesterday and I need 2 boosters. I knew I would need these as it was the same with bt broadband unfortunately sky don't send these as standard. Anyone know how I go about ordering these?
Re: How do I get wifi boosters?
@Damo1308 Sky only provide boosters as part of an add on bundle either Broadband Boost which costs £5 per month and gives up to one basic booster or Wifi Max which costs £7.50. The latter is the better deal as it comes with  a new faster hub and up to 3 extenders if an engineer agreed they are needed.
Otherwise you can buy your own which can be cheaper in the long run. It is best to buy a whole home wifi kit turn off the Sky hub's wifi and use the units from the kit in access point mode.
@Damo1308
Note that Sky may not accept a claim for loan of booster hardware under the terms of the WiFi Guarantee within the first two weeks of activation.
