11 Sep 2022 08:44 PM
How do I find out what ghz my router is?
11 Sep 2022 08:47 PM
If you mean the wifi bands then all sky hubs are 2.4ghz and 5ghz wifi except for the very old sr102
11 Sep 2022 09:18 PM
I'm looking to purchase a robo vacuum and it says it will only run on 2.4ghz
11 Sep 2022 09:21 PM
You would need to seperate the 2.4ghz and 5 ghz so you have 2 ssids and allocate the vaccuum cleaner to the 2.4ghz wifi band
- Log onto router and go to wifi
- Go to 5ghz band and untick synchronise 2.4ghz and 5ghz
- Go to 5ghz ssid and add -5g at the end
- Save
- Go to individual devices and assign wifi band accordingly
More detailed info
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
11 Sep 2022 10:19 PM
Thank you 😊
12 Sep 2022 07:07 AM
We have a Coayu robot and it found the 2.4 GHz fine.
17 Sep 2022 04:45 PM
I have just got a robot vac, I've spilt my channels, but the vac will not connect to the wifi at all, any suggestions? Password definitely correct, phone connected to the 2.4ghz.
18 Sep 2022 07:05 AM
Posted by a Superuser, not a Sky employee. Find out more@caroline92 see my rply to yourduplicate post.
