Discussion topic: How do I enable UPnP on the Sky router?
Message posted on 23 Dec 2024 11:38 AM
Hi,
It seems that the Sky router is very locked down. Is it possible to enable UPnP?
My VoIP phones are not working since switching to the SkyRouter.
Message posted on 23 Dec 2024 11:54 AM
Re: How do I enable UPnP on the Sky router?
@smithgt do you have a white or black Sky hub?
Message posted on 23 Dec 2024 02:31 PM
It's white - I Have FTTP if that makes a difference.
Message posted on 23 Dec 2024 03:27 PM
The toggle for UPnP is in the My Sky app, but you may well find that doesn't resolve the issue.
Message posted on 23 Dec 2024 03:47 PM
Where in the App?
Under Wifi/Advanced I only have Port Forwarding, DMZ, Disable Wifi & Wifi Security Level
Message posted on 23 Dec 2024 03:52 PM
@smithgt & @TimmyBGood unusually the uPNP setting is in the hub's web interface not the app see UPnP set up
However that setting may not sort your VOIP issue if it doesnt post again.as you will need ti get help from Sky.
Message posted on 23 Dec 2024 10:51 PM
The VOIP issue isn't resolved 😞
If I take the phone to another person's home network, the incoming calls are received okay.
At my home on the Sky router, no calls are received.
Do I need to create any port forwarding? (Ive not had to do this at the other locations) or is there another Sky related issue?
Message posted on 23 Dec 2024 11:11 PM
There's apparently an issue with the current firmware for the Max Hub and VoIP handsets: I can try escalation of your post to see if Sky will move it to a different version (as referenced in other forum threads)
Message posted on 24 Dec 2024 08:40 AM
type 192.168.0.1 into your search bar on the internet and the user name should "admin" and the password is your WiFi password. UPnP settings is on there somewhere as I enabled mine yesterday before my WiFi went down.
Message posted on 24 Dec 2024 09:17 AM - last edited: 24 Dec 2024 09:42 AM
Thanks for escalating this. We’ve already got an active chat with @smithgt
Please be aware, our Community chat closes at 6pm tonight and will re-open on 27th December at 8am.
Lisa - Sky Tech Team Expert
Message posted on 24 Dec 2024 12:49 PM
Hi
I had the same problem with SIP-ALG needing to be turned off for my VOIP phones.
I sent a ticket to https://www.sky.com/help/forms/vpn-configuratiuon
Explaining the issue, they replied and solved the issue with an update to my Router (new white one)
Ask them to turn off MAP-T
Message posted on 01 Apr 2025 08:08 AM
Log onto the router (192.168.0.1 in a browser) - Admin credentials as per bottom / back of router.
Go to Advanced -> Device Discovery -> Enable UPNP (button / toggle).
Message posted on 14 Apr 2025 02:27 PM
I have my UPnP enable on my Sky Max Router, but it fails to show the WAN IP, Status, and UpTime. This was after the Sky Team reset the router to try to enable Sky Pod, which is still not working. So they made it worst not better..... any ideas how I get this bac
