Discussion topic: How do I block a mobile using wifi
This message was authored by: Sarah3910
Message posted on 12 May 2025 01:24 PM
Hi is there anyway I can block a mobile using wifi after a certain time ?
Message posted on 12 May 2025 01:28 PM
Re: How do I block a mobile using wifi
@Sarah3910 If you have the Sky Max subscription you could have a try using the parental controls option.
