Discussion topic: No WiFi
Message posted on 12 May 2025 01:53 PM
No WiFi
I work from home and my WiFi has just stopped working however I have run tests and it states that it all ok but it's not
Message posted on 12 May 2025 01:56 PM
Re: No WiFi
I don't know what tests you have run some if rebooting the hub at the main doesn't bring it back to life then the first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
