Discussion topic: Hive Ethernet connection
This message was authored by: Mick142
Since going to Sky fibre my Hive which is connected via and Ethernet cable no longer works.  The Hive app keeps saying the Hub cannot connect to the internet
This message was authored by: Mr+Flibbles+86
Re: Hive Ethernet connection
Posted by a Sky employee
This message was authored by: Helen197
Hello I am having the same problem have you managed to sort this and if so how
Avatar for Mick142
No, I was hoping to find someone who could help
This message was authored by: FLC
I'd start by disabling Sky Shield. If it still won't connect, call Hive or check their support pages. They're usually pretty good at resolving issues.
I was advised by Hive that sky/ Now Tv are to open the following ports
The ports a Hive Hub requires are:
UDP port 123 (NTP)
TCP port 443 (HTTPS)
TCP 5671 (AMQPS)
@Mick142 & @Helen197 this something that comes up occasionally quite why the Huve hubs cannnot connect is unclear. I had this issue myself a few years back and found Hive support totally clueless. In the end I simply left the Hive hub connected overnight and it sorted itself. Despite several changes of Sky hub it has femained connected since then but for some reason I cannot figure it prefers to be directly attached to the Sky hub not to an Ethernet switch perhaps connected to tthe fact the Hive hub has a 10Mb/s ethernet port
My Hive Hub had no issues connecting to either the SR203 or SR213 routers, so I doubt there are any blocked ports. When it did randomly disconnect a few years back when I was with BT, their telephone support was excellent. Here's the help page for the Hubs:
https://community.hivehome.com/s/article/What-to-do-if-your-Hive-Hub-is-offline
Avatar for Mick142
Done that and sadly no change.  Thanks for the suggestion though 👍
Avatar for Mick142
Thank you I'll try the link
